8-Gravel
Dec 17, 2024 7:42 AM UTC
Add data utility to workflow variable
We are working on a task where it should have an input attribute with a suggestion box on a workflow task item.
I have created the data utility for the suggestion box. I need clue how to map it with my workflow variable(it is not straight forward as i do for type and attribute)
Kindly guide me
avillanueva
23-Emerald II
Dec 17, 2024 12:31 PM UTC
We accomplished this with a custom JSP template for the workflow task page. In this example, I was using a drop down for a WTUser that I wanted a custom limit on what users were selectable. Variable was called "EC_Creator".
<jca:describePropertyPanel var="ecCreatorPanelDescriptor" >
 <jca:describeProperty id="EC_Creator" dataUtilityId="goodrichPrincipalSelector" />
</jca:describePropertyPanel>
You are able to add in the call out for the ID of the data utility.
<tr>
 <td align="right" valign="top" nowrap><FONT class=tabledatafont>
 <tags:taskPanelLabel propertyModel="${ecCreatorPropertyModel}" attrs="EC_Creator"/>
 </td>
 </tr>
Then later on in the template, you can call out its rendering.
HelesicPetr
Dec 17, 2024 8:32 AM UTC
Hello @SK_12337814
Here is an example how to use dropdown list in the workflow task input.
CS36017 - How to create a drop down list in a workflow instance task detail page of Windchill
Unfortunately, when I tried this example, I realized that the standard DataUtility is not supported in the task input page.
PS> you can study what following DU does and get idea how to implement own one.
com.ptc.windchill.enterprise.workitem.dataUtilities.CustomVariablesDataUtility
mentioned DU is used to display Variables from workflow on the Task page.
PetrH
avillanueva
23-Emerald II
<tr>
 </td>
 </tr>
HelesicPetr
Dec 17, 2024 12:32 PM UTC
Hi @avillanueva
I was thinking about the jsp and javascript solution 😄
PetrH
