18-Opal
Nov 17, 2017 5:26 AM UTC
add life cycle status issue
Hi i'm SeonHo
There is an issue in adding the state to the life cycle.
Added new lifecycle status through the enumCustomize.bat command in the windchill Shell
I then saved it and used the Enumverify wt.lifecycle.State command in the windchill shell
However, the following message was printed
 EFFECTIVENESS APPROVAL:
   display = <status>
   abbreviatedDisplay = <status>
   fullDisplay = <status>
   shortDescription = <status>
   longDescription = <status>
   comment (deprecated) = <status>
   order = 0
   isDefault = false
   selectable = true
   stringValue = wt.lifecycle.State.EFFECTIVENESS APPROVAL
   enumValue = EFFECTIVENESS APPROVAL
    Localized error message test, not an actual error:
      There was a problem creating the object "<status>".
If you then use the Ant -f codebase / MakeJar.xml custUpdate command, you will see the following message
Buildfile: build.xml does not exist!
Build failed
I stopped windchill and started it again.
What should I do?
Thank you.
CHASEONHOAnswer
18-Opal
Nov 17, 2017 6:43 AM UTC
Resolved.
The environment variable for ant was not registered.
It is also because I tried to change while running windchill.
"Localized error message test, not an actual error:
       There was a problem creating the object "<status>". "
The message is still displayed, but you can add a lifecycle status.
CHASEONHO18-OpalAuthorAnswer
18-Opal
Resolved.
