Sep 4, 2025 11:42 AM UTC
Add Problem Report Type to Associated Process Objects Table of Change Notice
Hello. Does anybody know if it is possible to achieve the scenario above? I have created a custom "Problem Report Workflow". The OOTB "Problem Report Workflow" contains a synchronize robot that should result in the state change of the problem report being set to "Resolved" when the associated change request is completed. I have replicated this config with my custom problem report workflow but I have adapted the synchronize robot with the aim of it synchronizing when the change notice completes. This is in ciontrast to it synchronizing when a change request completes. I'm not aware of any issues with my new workflow. However, I've noticed that I cannot add problem reports into the "Associated Process Objects" table when creating the change notice. Consequently, I don't think I have a way of my problem reports becoming "Resolved" at the same time as the change notice completing if I cannot add the problem report to the change notice as an "Associated Process Object".
C_CardeyAnswer
Sep 4, 2025 1:32 PM UTC
Theoretically what you are asking is possible. It depends on your custom workflow.
Did you define an Association Rule that allows Problem Reports to be added to Change Notices?
I can suggest that you look at the course Windchill: Change Implementation.   The course covers the Problem Report Lifecycle and Workflow as well as how to create Association Rules.
I am unable to answer specific questions about a custom workflow in your install, but I hope I have pointed you in the right direction to find the answer.
Sep 4, 2025 12:21 PM UTC
Can I ask which PTCU course you are referring to?
Sep 4, 2025 12:25 PM UTC
Hi. I am not referring to any PTCU course. I am referring to behavior in my Windchill instance I am experiencing.
C_Cardey10-MarbleAnswer
