Feb 8, 2024 7:53 AM UTC
Added new value in Global Enum List, but the value is not getting reflected on WTPart create page at
I am using Windchill MPMLink Release 12.1 and Datecode with CPS 12.1.2.1
Added new value in Global Enum List, but the value is not getting reflected on WTPart create page attribute.
Here are the errors that I faced
Rocket_Max
Feb 8, 2024 8:52 AM UTC
Hi @AS_10652879
Stop Windchill and clear tomcat\I*E\Browser cache , then try again.
Provided your steps of Added new value in Global Enum List if above method not works
HelesicPetr
Feb 8, 2024 9:53 AM UTC
Hi @AS_10652879
Your problem can be issued by using more MethodServer instances.
If you use more then one methodserver, sometimes the change is not synchronized between others method server instances so the change in the type and attribute management is applied to all method servers after a Windchill restart.
This is common situation when server restart is the solution.
PetrH
Feb 9, 2024 6:26 PM UTC
Hi ,
Can you try just restart windchilll services or stop the windchill service then clear the caches in server then start the windchill services in shell
or if not updating check the attribute hidden and un hidden check box
