Oct 15, 2025 10:50 AM UTC
Adding a NonVersion Attribute to WTDocument
I am using Windchill Aerospace & Defense Release 12.1 and Datecode with CPS 12.1.0.1
We need to flag the WTDocument with Compliance ready/ Approved/ Rejected without iterating/ revising the WTDocuent. How can we do that ?
Tried to Add a non versioned attribute to WTDocument Master . However , that is not visible to user in UI
    Fadel
    23-Emerald II
    Oct 15, 2025 3:22 PM UTC
    We can Create and alias attribute on wtdoc referencing master attribute but it will be exposed to the edit layout which will iterate the doc :
    Second option is to customize the rename document wizard to add the master attribute  .
    Buiꓘa
    18-Opal
    Oct 27, 2025 9:50 AM UTC
    Hi @Fadel,
    In the first option the attribute can always be removed from edit layout right?
    Fadel
    23-Emerald II
    Oct 27, 2025 1:44 PM UTC
    yes , later on we can remove  attribute from layout
    Buiꓘa
