Sep 25, 2015 2:16 PM UTC
Addtional Sequences: WC 10.2 M010. SQLPLUS error.
Trying to execute sqlplus in a Windchill Shell so I can create a custom sequence using the string bellow.
exec wtpk.createSequence('seq_name',start_num,inc_value).
Getting error: sqlplus  is not reconized as an internal or external command.
Regards
Patrick
2-Explorer
Sep 25, 2015 7:02 PM UTC
It should be the PDMLink credentials. Refer to wt.pom.dbuser in WT_HOME/db/db.properties
Thank you
Binesh Kumar
Barry Wehmiller
2-Explorer
Sep 25, 2015 3:36 PM UTC
It looks like you don't have oracle client is not installed on Windchill server. Download the oracle client, update the tns entries for windchill database and try again.
Thanks you
Binesh Kumar
Barry Wehmiller
pstapler1-VisitorAuthor
Sep 25, 2015 3:41 PM UTC
I don't see that as an option from the PTC website.
2-Explorer
Sep 25, 2015 5:05 PM UTC
You can download the oracle client from Oracle website.
Another option is to run it from the db server directly. From the db server, logon to SQLPLUS and run the command.
Thank you
Binesh Kumar
Barry Wehmiller
