Dec 9, 2019 10:11 AM UTC
Advanced Configuration Logic in Windchill 11
Hi
I am catching up with the changes from Windchill 10 to Windchill 11 and one thing I came across is that it seems that PSE is no longer available on Windchill 11. I have been told by IT that when moving to the web PTC removed PSE.  I have found this very strange. However, the bottom line is that I cannot find in the interface how to start it, so I had to believe them. This said, I have just read the help files that goes with our version of Windchill 11 and it mentions to launch PSE in order to create advanced configuration logic. So this would mean that PSE is still available.
I am confused though as if it is available, why I cannot launch it and if IT is right and it is no longer available, then how do we do advanced configuration logic now. What's PTC plan.
Thank you in anticipation to whoever is going to bring some light 🙂
Best regards
Dec 19, 2019 7:58 PM UTC
There is a parameter at the site level for advanced logic...set to yes.  You will now see new tabs in the PSB for configurable parts:   parameter and constraint.
