After Configuring Upgrade Test server, license count get double on Production server.
We are upgrading from Windchill 12.0 to Windchill 13.0 on the test server, and I see the license count on the Production server has doubled compared to the previous license count once done with the Test upgrade. We are using local LDAP and not enterprise LDAP is that the issue or any other reason?
    This is a bug in PTC's license management page. I thought PTC fixed it, but maybe not.  The issue is in PTC's license management page, not your Windchill implementation.
    When you clone an existing server to create a new one, it automatically includes the license counts from the source server.  The licensing workflow allows continues on, allowing you to assign a full count of licenses to new the clone server.  This doubles the number of licenses assigned to the server.  If you clone it again, you can repeat the process and have triple your total available licenses assigned to a single server.
    Go back into license management and remove all licenses from your defined production system.  Then assign the full set of available licenses to it.  That should fix your issue.
    Community Moderator
    November 13, 2025
    Hello @Devidas(Devi),
    It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
