Jul 28, 2016 4:23 PM UTC
After creating a New Project from a Project Template (Having a Document Structure), Document Structure is not propagated in the newly created project.
Step 1 - A project was created
Step 2 - A document structure was created in it
Step 3 - This Project was saved as a Project Template
Step 4 - A new project using the above template was created
The Document Structure did not propagate in the newly created project. However, all the documents were propagated individually
Aug 8, 2016 4:57 PM UTC
Hi Prasad,
I believe this is limitation of the software, currently only documents are populated the structure is not retained.
Bhushan
