Sep 24, 2019 12:52 PM UTC
Ajax Request and Component Builder
I followed the split pane example to have multiple JSPs displayed on one site. It works pretty well with JSPs that are located in /netmarkets/jsp but unfortunately the AJAX part doesn't work with views that I created for a Component-Builder.
The problem seems to be the URI to the view as it contains a "#". Thus the URI is cut off when being sent to the backend via AJAX.
Here is a code snippet which is pretty close to the split pane example. As can be seen the URI contains a "#". Is there any way to send the whole URI via Ajax?
if (contentPanel !== undefined) {
	contentPanel.clearCardContents();
	var options = {
		asynchronous : false,
		method : 'get'
	var transport = requestHandler.doRequest("http://www.serverxyz.com/Windchill/app/#ptc1/comp/com.example.Test.jsp", options);
	var panel = new PTC.Panel({
		renderTo : renderToDiv,
		html : transport.responseText
Sep 25, 2019 12:16 PM UTC
After reading the Customization Guide again I came to the conclusion that it won't even help me if the URI is not cut off after the '#'. The problem simply lies in the way URIs are handled in Windchill.
The part after the # is already being used by AJAX calls and they also don't work independently. That's why I don't see a way to make this work like that.
