3-Newcomer
Jul 21, 2025 1:28 PM UTC
Algorithm used by windchill to encrypt passwords.
Version: Windchill 12.0
Use Case: I wanted to decrypt the db password from windchill, wanted to know which algorithm ptc is using to encrypt the password. Suggest the steps to decrypt the db password from windchill.
Description:
Jul 21, 2025 2:15 PM UTC
avillanueva
23-Emerald II
Jul 21, 2025 3:09 PM UTC
https://support.ptc.com/WCMS/files/124751/en/WCAdminConfigWCEnvGuide.pdf
page 62 says this:
To encrypt system passwords, Windchill and Info*Engine code uses a JCEKS KeyStore class in conjunction with a password-based encryption. JCEKS KeyStore is a strong version of the Sun KeyStore class implementation. The Sun KeyStore implementation is standard with the Java SE Development Kit (JDK).
Catalina
Community Manager
Aug 1, 2025 11:24 AM UTC
Hi @MK_13455749,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
