Aug 5, 2020 11:16 AM UTC
Alias Attribute to show attachment of Change Task on Change notice
How can I display the attachment(s) which are on the change task(s) on the change notice the change tasks belong to ?
Or how can i get the attachments of a change tasks ?
Aug 5, 2020 7:50 PM UTC
Adding/removing of Attachments is supported directly in the Change Task.
You won't see that table in the Change Notice wizard, but will be seen on the Change Task information pages and can be edited from the Change Task edit actions.
uharneit15-MoonstoneAuthor
Sep 17, 2020 10:45 AM UTC
Thanks, I managed to get the names of the change task attachments displayed but that was not enough for customer
avillanueva
23-Emerald II
Aug 31, 2022 4:25 PM UTC
Ok, how did you do it and what was the result? I see shortly after this posting a PTC article was created with this very topic:
How to make attachments on the Change Task´s show up on the Associated Change Notice in Windchill PDMLink
However, this gives what appears to be an incomplete mapping nor does it show how the output looks:
Something appears missing. File attachments have multiple attributes and can be numerous. You can also have multiple change tasks each with their own attachments. Will it show were that attachment was from?
