Jul 25, 2014 5:50 AM UTC
All the cad jobs are failing. Below is the error. Please help
Recipe file: D:/ptc/creo_view_adapters_3.0/proe_setup/proe2pv.rcp
[2014-07-24 23:13:33] Source file: jaa285cnc_g.prt
[2014-07-24 23:13:33] Output file: D:/productionShare/CadWorker/w2i1j2425/jaa285cnc12_prt.pvs
[2014-07-24 23:13:33] Registering Server : [2014-07-24 23:13:34] proe2pv Error:56113: Failed to register Windchill server "https://windchill.otis.com/Windchill" "publish7322861575475682051tmp" - -22
[2014-07-24 23:13:34] proe2pv Error:13027: Cannot restart adapter, helper returned "Adapter already restarted once"
May 12, 2015 3:17 PM UTC
I am having the same issue. Has anyone cured this problem.
MarcoTosin
May 12, 2015 3:30 PM UTC
When the server failed to register, one thing to verify depends if it's on HTTP or HTTPS.
If your Windchill is configured on HTTPS, the java certificate MUST be from a trusted authority.
Search on TS or in the community for "worker java"
Marco
May 12, 2015 10:46 PM UTC
The config.pro options listed in Ron T's post seemed to fix my issue....see this post Worker process 'Fails to Start'
Thank you all for the responses.
May 13, 2015 12:44 PM UTC
Need a little more info. What version of Creo are you running? What adapter version are you using to publish? Are you running multiple workers on the same machine? I had a similar issue that was caused by Creo not clearing all the running processes on an exit.
