11-Garnet
Feb 27, 2024 6:25 AM UTC
Allocated part shows design view in structure (Windchill Version 11.1 M020 CPS 22)
I have process plan and operations with Manufacturing view. There are parts allocated to operations, in structure allocated part shows design view.
How can we see default view as manufacturing in structure tab for allocated parts ?
Is there any preference can be use to achieve this?
HelesicPetr
Feb 27, 2024 9:08 AM UTC
Hi @K_Patil
You need to have correct view of the process plan and operation.
Then the default filter use manufacturing definition and then you should see the manufacturing views if exists
If user does not check the filter setting during allocation, then  yes he can do a mistake.
Also one preference exists that manufacturing view is used for wtpart, process plan and other types creation
Default Part View
Each user can set this preference so every manufacturing user can set it to MFG and then always the user create Process plans and operations with Manufacturing view
PetrH
HelesicPetr
Hi @K_Patil
Default Part View
PetrH
K_Patil11-GarnetAuthor
11-Garnet
Feb 28, 2024 4:10 AM UTC
Hi @HelesicPetr ,
Thank you for the help.
