Jul 22, 2026 12:43 PM UTC
Alternatives to Adobe AEM for Coversheets generation
Since the support for Adobe Experience Manager is being deprecated I’m looking at the workflows dependant on PDF publishing with AEM.
I had a look at the free trial of the WEX coversheets extension and it’s fine but I’d need to make a few changes before it would be a drop-in replacement for the coversheet generation customisation we have with AEM currently.
Has anyone found any alternatives?
At the moment AEM converts html files to PDF and merges them with a PDF of the primary content to create the PDF representation file, the primary content can be any office file. AEM does this via a SOAP webservice which you can inspect via it’s WSDL and it seems AEM has far more capabilities than Windchill actually needs so I’m wondering whether to try replacing it with a service that does the html/PDF conversion and merging with a simpler app based on plain java HttpServer and openhtmltopdf?
I ran TCPMON to capture the requests and responses between Windchill and the AEM Assembler Service and it seems Windchill is only ever calling one of three services, the WSDL, invoke or invokeOneDocument - so it should be possible to create an app that pretends to be AEM and provides the same SOAP responses?
Appreciate any thoughts
Catalina
Community Manager
Aug 7, 2026 11:54 AM UTC
Hi ​@rhart
Thank you for your question. 
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Catalina | PTC Community Manager
jbailey
18-Opal
Aug 13, 2026 11:16 PM UTC
What’s the enhancements needed for WEX Coversheet?
rhart16-PearlAuthor
Aug 14, 2026 10:03 AM UTC
WEX adds the coversheet to the primary content file, but in our workflow the primary content is an office document and the coversheet is added to the representation.
I’ve replaced the AEM with a Java Httpserver which mimics the AssemberService for now.
jbailey
18-Opal
Aug 14, 2026 11:49 AM UTC
So the limitation is that the trial expired?
Dobi
Aug 15, 2026 4:03 AM UTC
We have WEX installed but ended up writing our own code using https://pdfbox.apache.org/.
That, coupled with the AfterEDRLoader gave us all the overlay and coversheet functionality we need and I would highly suggest that route if you feel comfortable with a little bit of backend code.
