20-Turquoise
July 26, 2023
Amazon Corretto 11.0.20 and 17.0.8 warnings
  • July 26, 2023
  • 3 replies
  • 2660 views
2 new articles on PTC dealing with issues with Amazon Corretto 11.0.20 and 17.0.8
https://www.ptc.com/en/support/article/CS397632
https://www.ptc.com/en/support/article/CS397375
I just tried 11.0.20.8.1 on a test Windchill 12.1.2.2 server and I also have this issue (CS397632) of Windchill failing to start. I don't have a Windchill 13 install to test. I have not tried running a PSI solution either with this.
On my laptop I can also vouch that upgrading the java from Amazon Corretto 17.0.7.7 to 17.0.8.7, that my Eclipse sees that it has many "can't find class" errors. Downgrading from 17.0.8 back to 17.0.7 fixes the Eclipse issue.
Best answer by RandyJones
Amazon corretto has updated 11.0.20.8.1 to 11.0.20.9.1 which fixes this issue for me. I also note that 17 has been updated from 17.0.8.7.1 to 17.0.8.8.1. My guess this same bug has been fixed in 17 also although I don't have Windchill 13 to test it on.
avillanueva
23-Emerald II
July 26, 2023
I check change log in github and saw no mention of anything related to Apache Ant.
20-Turquoise
July 26, 2023
RandyJones20-TurquoiseAuthorAnswer
20-Turquoise
August 24, 2023
