Mar 6, 2013 9:59 PM UTC
Anyone know how to do this - run a remote process and insure it is in the Windchill shell for a PC
I want to run psexec (part of Microsoft pstool set) to connect to a series of remote machines and kick off commands that are dependent on being in the Windchill shell. For example windchill start or windchill stop. I do not want to have any sort of daemon or scheduled job running - I want to essentially login the psexec and either be in the Windchill shell or start a windchill shell and tell it to do something. One way I can think to do this is to not bother and just make sure my environment matches the shell, but that seems like it will eventually break - I will get out of synch.
I would have thought this would be any easy problem to solve, but I am stumped a bit. Any ideas or suggestions are greatly appreciated.
I tried running a windchill shell and trying to redirect a command into it
windchill shell < dothis.txt
where do this is
windchill start
but that does not work.
--Bob
Mar 6, 2013 10:18 PM UTC
Hi Bob, if the tasks are known tasks you can create batch scripts for each one (containing shell command line, which can be found by RMB on OOTB WC Shell Shortcut) and then use PSEXEC to execute these commands natively on the server. My guess is that you are wanting to just plain and simple have a remote Windchill Shell, which I don’t know how to do though.
[cid:image001.gif@01CE1A6D.0856B260]
Steve Vinyard
Senior Solution Architect
Mar 6, 2013 10:46 PM UTC
Bob,
If Windchill is running as service on Windows, then you don't need to
use windchill shell. I used *sc* (Service Control)* *command along with *psexec
*in the past to start,stop, restart Windchill and other services on remote
servers.
psexec <server-name> 'sc start *PTCWindchill*'
psexec <server-name> 'sc stop *PTCWindchill*'
PTCWindchill is Windows service name
Prathap <">http://goo.gl/LuT5>
Mar 6, 2013 11:24 PM UTC
Prathap,
Yes, that is correct - those were just an example - say I want run an ant script to rebuild the resource bundles on 5-10 method servers or some other command where I pretty sure I need all the windchill shell setup.
--Bob
Mar 7, 2013 2:37 AM UTC
Learn ANT, you’ll waste less time, and once you do, you can find that there is much help already in the codebase to help you with stuff…
Mar 7, 2013 3:06 AM UTC
Hi David,
Thanks for response.
I know ANT and use ANT, how does it help with this particular problem - you still have to figure a way to set your environment or work within the context of the shell and I want to be able to fire the request remotely in a PC environment. Am I missing something fundamental here or am I describing the problem poorly?
--Bob
Mar 7, 2013 1:31 PM UTC
Bob,
On Windows the Windchill shell environment must be recreated by your batch file. You can't use "Windchill Shell" because it breaks the 'link' to your batch file and won't let you run any subsequent commands. Iposted a solution to this last spring: http://portal.ptcuser.org/p/fo/st/topic=16&post=106961#p106961
Using this technique you can batch script Windchill commands and call your batch file via psexec.
Kind Regards,
Matt Meadows
Solutions Architect
VIRSO Inc
O: 618 937 8115
C: 314 749 8377
E: mmeadows@virsoinc.com
Dec 16, 2015 4:45 PM UTC
Really glad I found this thread and Matt's solution.  Currently having some Windchill issues, as a temporary work around need to use a windchill shell in a batch file, couldn't figure out how to do this until I came across this post. Very disappointing in when I asked PTC tech support they would not offer any assistance, especially when it was related to an open case.
