Anyone using Cognos business reporting with SSL enabled PDMLink?
We have some custom Cognos reports which were working fine with PDMLink. As a part of ProjectLink implementation, we have enabled SSL in PDMLink. To make Cognos reports to work with SSL enabled PDMLink, we tried the below TPI from PTC website:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=kA1A00000000CbEKAU).
However we could not run the Cognos reports. We get an error 'The report server not responding' on the GUI and a large core file gets generated under Reporing/bin directory. Wehave beenworking with tech support for last few weeks to get a resolution for this issue.
Is there anyone using Cognos reports with SSL enabled PDMLink? Did you face similar issue? Please let me know, I would like to hear your suggestions.
Thank you!
Dhana.
