anyone using WGM for SolidWorks, including "Toolbox"
  • April 3, 2012
  • 5 replies
  • 2790 views
has anyone out there been managing solidworks data with Windchill via WGM for Solidworks?
more specifically, to you use "solidworks toolbox", and if so, has it "worked well" or perhaps it has presented complications?
thanks for any experiences!
Barry
Not yet, I am trying to do a system start-up with toolbox and am already faced with issues. I have toolbox loaded on peer PCs locally and going to the vault is possing a major problem. I am trying to get info from PTC on solutions.
Frank Raspante
Hydroid 508-563-6565
Hello Frank,
please be aware that WC 10.1 M010 (released two days ago!) supposedly has the fix for toolbox, and that 10.0 M030 does NOT handle toolbox correctly. I was told that 10.0 M040 would have the fix, however that is not planned for release until August.
months ago SolidWorks changed the behavior of toolbox and PTC is now catching up with the change. If you are on other than 10.X I'm afraid you will need to reach out to PTC to see when they will adjust your version to again match the new toolbox behavior as implemented by SW.
good luck!
Barry
