8-Gravel
May 8, 2025 6:31 AM UTC
ApacheDS replacement for WindchillDS
Version: Windchill 13.0
Use Case: WindchillDS to ApacheDS migration
Description:
Is there any documentation on how to migrate from WindchillDS to ApacheDS? Environment is Windows/Oracle/Windchill 13.0.2. Thanks.
Catalina
Community Manager
May 8, 2025 10:58 AM UTC
Hi @rpike
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • What specific steps have you taken so far to migrate from WindchillDS to ApacheDS?
  • Can you provide more details about your environment setup (Windows/Oracle/Windchill 13.0.2)?
  • What specific challenges or issues have you encountered during the migration process?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
rpike8-GravelAuthor
8-Gravel
May 8, 2025 11:26 AM UTC
Thanks Catalina. I was hoping there might be some step-by-step article that describes the process (just as there is for OpenDJ) but since that doesn't appear to be the case then I'll provide more detail here. The Windchill system in question consists of 2 servers (Windchill server and database). WindchillDS is installed on the Windchill server. Windchill system is at 13.0.2 running PDM/ProjectLink. All servers running Windows Server 2019. Database is Oracle 19. I'm looking at replacing WDS with ApacheDS. I have installed Apache Directory Studio on the Windchill server and exported the current LDIF from WDS. I am assuming I need to import that LDIF into ApacheDS but I'm pretty sure I need to modify the LDIF before that (or maybe after import). Currently ApacheDS looks like this:
Not sure what to do next.
Thanks.
avillanueva
23-Emerald II
May 8, 2025 12:07 PM UTC
The most important thing is that the users go into the same branch path as they are currently in WindchillDS (which is really OpenDJ repackaged). The database has that path stored so if they are not aligned, you will get disconnected users. The commands for import and export might be different but process should be the same.
Fadel
23-Emerald II
May 8, 2025 11:50 AM UTC
Take a look at this hub article https://www.ptc.com/en/support/article/CS337554
Buiꓘa
