Oct 4, 2016 3:07 PM UTC
API for publishing additional formats
Hi, Is there an API to publish the additional format like step, iges, x_t for an epm document?
Oct 4, 2016 7:17 PM UTC
I'm not sure about an API, but have you looked at Publishing Rules? The following documentation may be helpful:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS53670
http://support.ptc.com/WCMS/files/138204/en/WindchillVisualizationServicesGuide_10-1_M050.pdf‌ - Page 60?
Support for publishing additional file types was added in Windchill10.1.
Oct 10, 2016 6:34 PM UTC
I haven't found any solution just to publish a 2nd content like dxf or step and add it to the CADDocument. With publish rules you can also create a WTDocument with the dxf. But WTDocuments and CADDocument makes the dependencies much more complicated. I also looked once for a solution to create a visualization just with a step and without the CreoView files.
Mar 9, 2018 12:13 PM UTC
Hi mmolla-3,
Did you ever find a solution for this? We want to do the same thing in our company and I can't find a possible solution.
