BenPerry
Aug 20, 2015 11:53 PM UTC
API for Windchill User Login Event
When a user logs in, there is a record added to the database in the AUDITRECORD table.  I assume some java code is executed when a user logs in, to put that record in the database.
I was thinking about leveraging this API to do some additional things, such as check the user's preferred file server (their vaulting preference).  I could add additional code to this java class do what I desire.  But first I need to determine what API is triggered during the login.
Anyway have ideas of which API(s) are triggered during user login?
Aug 21, 2015 6:22 AM UTC
Whenever a user logs in I think SessionUserAuditEvent.LOGIN event is fired. See if you can do what you want in this event listener.
BenPerry
BenPerry15-MoonstoneAuthor
Aug 21, 2015 11:04 AM UTC
Abdul,
Thanks.  I added a System.out.println() statement to SessionUserAuditEvent(), but I didn't see anything in the MS or BMS logs.  Should I expect to see something there?  Or somewhere else?
  public SessionUserAuditEvent(String paramString, WTPrincipalReference paramWTPrincipalReference, long paramLong, int paramInt)
    super(paramString);
    this.event = paramString;
    this.user = paramWTPrincipalReference;
    this.time = paramLong;
    this.concurrency = paramInt;
    System.out.println("\n\n\n\n\nMyStatement\n\n\n\n\n");
