Oct 6, 2015 11:34 AM UTC
API to create EPMdocument with two iterations. A.1 and A.2
Hi All,
I am able to create a EPMDocument with API at first time.
i want to iterate this EPMdocument for updating its contents, how i can do this, because my code gives me "Error in Document Createwt.vc.VersionControlException: wt.util.WTException: wt.pom.UniquenessException: CAD Part" exception.
Please help me to Build the EPMdocument A.1 and A.2 with modified contents.
any help will be great.
Vivek
Oct 6, 2015 2:24 PM UTC
Hi.
You can create EPMDocument A1 and add the content. Then check out it, modify content and check in it.
vuchekar1-VisitorAuthor
Oct 7, 2015 10:27 AM UTC
Hi Anton,
Thanks for your response.
Now i am able to check out the EPMDocument with API, and check in back to Windchill without modifying the content.
as simple part A.1 to Part A.2.
but when i am trying to update its content, it gives me below error, please suggest how i can modify the content file also while check in i to Windchill.
Uploading file to Primary
java.lang.reflect.InvocationTargetException
  at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:800)
  at wt.clients.util.RMIMultiPartPost.performOperation(RMIMultiPartPost.java:257)
  at wt.clients.util.http.HTTPUploadDownload.performUploadOperation(HTTPUploadDownload.java:1357)
  at wt.clients.util.http.HTTPUploadDownload.access$100(HTTPUploadDownload.java:54)
  at wt.clients.util.http.HTTPUploadDownload$HTTPUploadDownloadThread.run(HTTPUploadDownload.java:2728)
Finished uploadFile of [wt.epm.EPMDocument:194491]Caused by: (wt.content.contentResource/66) wt.content.ContentException: Can not add more than one primary content to the object.
i am using below code for check out EPMDoc.
//check out
        wt.vc.wip.WorkInProgressHelper.service.checkout(doc, wt.vc.wip.WorkInProgressHelper.service.getCheckoutFolder(),"Iterated by Administrator");
        System.out.println("Checked Out ...done.");
//for Check In
if(wt.vc.wip.WorkInProgressHelper.isCheckedOut(epm)) {
  epm = (wt.epm.EPMDocument) wt.vc.wip.WorkInProgressHelper.service.checkin(epm,"checked in by xxx");
Please let me know how i can modify the content of EPMDoc and check in back to Windchill.
Any sample code will be great help.
Vivek
Oct 7, 2015 11:27 AM UTC
Hi Vivek. I have never updated primary contents by code, but I am using below code for seting the secondary content:
public static void addDescribeFileToDoc(WTDocument wtd, File file) throws Exception
  System.out.println("Add secondary");
  byte[] byteArray = FileUtils.readFileToByteArray(file);
ContentHolderHelper.setContents(wtd, byteArray, ContentRoleType.SECONDARY, file.getName(), "", false);
You may try to change this method like this:
public static void updatePrimaryFileToDoc(WTDocument wtd, File file) throws Exception
ContentHolderHelper.updateContents(wtd, byteArray, ContentRoleType.PRIMARY);
