Mar 11, 2015 4:14 PM UTC
API to get the Resulting Object(s) from Change Notice.
Hi all,
Can anyone help me with an API to fetch the resulting objects from a change notice?
Mar 11, 2015 5:49 PM UTC
Hi Praseeth,
You can use ChangeHelper2.service.getChangeablesAfter() to fetch the resultant objects associated with an ECN object.
Just pass the ECN object as an argument to the above mentioned API and it will return you the resulting objects as a QueryResult.
Let me know, if you need more info.
