7-Bedrock
Sep 24, 2024 11:14 AM UTC
API to link non latest EPM Document to WTPart using EPMBuildRule
Version: Windchill 12.1
Use Case: I want to attached non latest EPMDocument to WTPart using EPMBuildRule
Description:
Hello All,
I want to attached non latest EPMDocument to WTPart using EPMBuildRule but it is always taking latest version of EPMDocument.
How can we do that?
avillanueva
23-Emerald II
Sep 24, 2024 11:19 AM UTC
Are you trying to do this via a code customization or manually from a workspace? Curious as to why you would want to do this?
7-Bedrock
Sep 24, 2024 11:32 AM UTC
Hi @avillanueva ,
I want to do it via code.
18-Opal
Sep 26, 2024 7:48 PM UTC
@BA_10780502
Post your code so that we can see where you are going wrong.
joe_morton
Sep 30, 2024 7:30 PM UTC
Could you describe a little more what the end goal is?
I recently looked into something that may be related. If you have:
  • CAD document 1 rev A with Owner link to WTPart 1
  • CAD document 1 rev B with Owner link to WTPart 2
Every time you do a build of a CAD assembly using that CAD document, the resulting WTPart structure will use WTPart 2.
I'm not sure what your end goal is, but setting the links may not be enough. I think the Build action itself uses the latest version of the CAD.
HelesicPetr
Oct 1, 2024 6:37 AM UTC
Hi @joe_morton
Actually, the link is a version to version so iteration to iteration.
You can have links between each iteration EPM-WTP
PetrH
Oct 5, 2024 2:12 AM UTC
I could use some more context here, and note as @HelesicPetr  states below, the EPMBuildRule link is actually between versions, not between iterations (take a look at the database table - the values are BRANCHIDA3A5 and BRANCHIDA3B5 which point to BRANCHIDITERATIONINFO).
That said, a code fragment to create one is below -- this does not run a build or anything else, it just creates the link.
WTPart workingPart = (WTPart)WorkInProgressHelper.service.checkout(wtPart, WorkInProgressHelper.service.getCheckoutFolder(), "").getWorkingCopy();
EPMBuildRule epmBuildRule = EPMBuildRule.newEPMBuildRule(epmDocument, workingPart, CADHelper.OWNERLINK);
PersistenceHelper.manager.store(epmBuildRule);
WorkInProgressHelper.service.checkin(workingPart, "Link with CAD");
