May 16, 2013 11:06 PM UTC
API to Programatically Export Product/Library Templates
I need to build a couple of development boxes. I would like to build empty systems with the same products, folders, lifecycles, etc. as the productions boxes. I was thinking that if I could programatically export templates of each of the products it would be easy to rebuild the system framework using loadfiles.
What API is there to export Product/Library Templates.
Stuart
May 16, 2013 11:46 PM UTC
Stuart,
There is an API for this, but I cannot recall where. With Eclipse you can search API for export. Alternatively follow the action OOTB to reverse and follow it that way to the API. You'll still need a loadfile to load the templates and establish the instances.
Sent from my Verizon Wireless 4G LTE Smartphone
Dec 6, 2016 7:43 AM UTC
Hi Stuart,
Were you able to find that API that would automatically export Product/Library Templates?
I am currently in search for such APIs and its methods. It would be really helpful, if you could give some information about it
Thanks in Advance.
Ganesh.
Dec 6, 2016 9:04 AM UTC
It works with following method:
* Saves the context template to disk
* @param template
* @param basePath
* @param filename
public static void saveContainerTemplateToDisk(WTContainerTemplateMaster template, Path basePath, String filename) throws WTException {
  DefaultWTContainerTemplate containerTemplate = template.getContainerTemplate();
   Path filePath = basePath.resolve(filename);
   logger.debug("filePath = " + filePath);
   File file = filePath.toFile();
   InputStream inputStream = null;
   OutputStream outputStream = null;
   QueryResult queryResult;
  try {
  queryResult = ContentHelper.service.getContentsByRole(containerTemplate, ContentRoleType.BUSINESS_JAR);
  if (queryResult.size() == 1) {
  ContentItem contentItem = (ContentItem) queryResult.nextElement();
  if (contentItem instanceof ApplicationData) {
   if (!file.getParentFile().exists()) {
  file.getParentFile().mkdirs();
   if (file.exists()) {
  file.delete();
  ApplicationData applicationData = (ApplicationData) contentItem;
   Streamed streamed = (Streamed) applicationData.getStreamData().getObject();
   inputStream = streamed.retrieveStream();
   outputStream = new FileOutputStream(file);
  int read;
  byte[] bytes = new byte[1024];
  while ((read = inputStream.read(bytes)) != -1) {
  outputStream.write(bytes, 0, read);
  } catch (WTException e) {
   throw new WTException(e);
   } catch (FileNotFoundException e) {
  e.printStackTrace();
   } catch (IOException e) {
   } finally {
   if (inputStream != null) {
   try {
  inputStream.close();
   if (outputStream != null) {
   try {
  outputStream.close();
Dec 6, 2016 4:35 PM UTC
Hi Bjorn,
Thanks for your quick response.
If I am understanding it correctly, the code that you have shared writes a Template to the Disk.
What I wanted is, that I need to extract the configurations of a Existing product and save it or export it as a Template. And I cant seem to find the API which will extract the configurations of this existing product to a template. Please let me know if you have any information about this.
Thanks in advance.
Ganesh.
