Jan 7, 2015 10:34 AM UTC
Applets are Failed to Load
Hello All,
On Monolithic Windchill Server 10.1M040, All Applets are failed to load.
Its shows a message in Pop up's as below,
The following error occurred during initialization: The operation: "getGlobalDomain" failed.
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method
Nested exception is: wt.util.WTRemoteException: Unable to locate method server
Nested exception is: wt.util.WTRemoteException: Unable to get server
Nested exception is: java.security.AccessControlException: access denied ("java.net.SocketPermission" "127.0.0.1:5002" "connect,resolve")
Please guide us to solve this.
Vivek
Jan 7, 2015 1:13 PM UTC
Apr 29, 2015 9:47 AM UTC
Thanks!
This fixed my problem as well.
Nested exception is: java.security.AccessControlException: access denied ("java.net.SocketPermission" "connect,resolve"); nested exception is:
(wt.fc.fcResource/0) wt.util.WTException: The operation: "getObject" failed.
Jan 12, 2015 11:13 PM UTC
What version of Java are you using on the client machine?
Jan 13, 2015 8:59 AM UTC
Normally I use Java 1.7.25 but the issue there is with Java 8.
The article solved the issue for me.
vuchekar1-VisitorAuthor
Jan 13, 2015 9:07 AM UTC
Hello All,
Thanks for your suggestions and response.
This issue was fixed after editing java.policy file.
Vivek
