May 19, 2025 3:08 PM UTC
Are the Report Builder Database Functions restricted based on roles, permissions or other?
I am trying to use the Maximum Database Function in Report builder to get the highest revision and version, as mentioned in this support article: https://www.ptc.com/en/support/article/CS27872
The function does not show in the list of available functions for me. Our System admins can see all of the functions and use them but I can not as an Org Admin or Product Manager, I see only a subset of the functions. I also can't successfully run a report that the admin used the Maximum function on.
The windchill help center pages mention all the available functions (https://support.ptc.com/help/windchill/r12.1.2.0/en/#page/Windchill_Help_Center/querybuilder/QBSelectOrConstrainDatabaseFunction.html#) and  i do see some of them, just not all of them and i haven't found mention anywhere that these can be restricted based on role or access control rules.
I've searched around on the topic a bit, but have not found much info on this issue.
MarcoTosin
May 19, 2025 3:43 PM UTC
Marco
May 19, 2025 6:06 PM UTC
So its a hardcoded restriction that couldn't be modified other than granting Site Administrator access to the user creating the report?
MarcoTosin
May 20, 2025 6:41 AM UTC
You can get the answer to your question directly from PTC support.
Just press on the button at the bottom of the article
On the next screen select the choice that is most relevant to what you want to ask and do so in the box below the choice.
A support engineer will answer your question
Marco
May 21, 2025 2:43 AM UTC
This issue has 2 parts:
1. Creating report templates
2. Using report templates.
I can't really help you with 1st part. You can try creating report templates on a test server, where you can give more people admin rights.
With using reports like this - there is a workaround. You can add new reports to the list of the OOTB templates and Windchill won't check if users have rights to use them.
You can find this list 'OOTB_ReportTemplates_advanced.xml' in '\codebase\registry\wt\query\template\' folder.
Dmitry
MarcoTosin
May 21, 2025 2:29 PM UTC
There is also this article that could help
Non-site admin users unable to edit or generate a report from a report template with "Bypass Access Control"
I used option 1 among the solutions proposed by PTC.
Instead of entering each individual report into the list, simply create a new site-level group and enter the users who need to see or edit the report.
Marco
