Oct 4, 2013 12:46 PM UTC
Assign serial numbers and effectiveness
I would like to know if there is a complete manual where I can find a full explanation about how to assign serial numbers and how to manage the effectiveness. The Help from PTC is not enough, we have never dealt with it in our company.
Is there any tutorial available with examples to make?
Thanks.
Carolina
GregoryPERASSO
Oct 4, 2013 1:31 PM UTC
Hello Carolina
PTC has not really good training material about effectivity management . There's probably PTC guys how can help you on this topic. They should work on the Aerospace & Defence aera.
Effectivity management , refers more widely to "Configuration Management" . And Change Management is one of the corner stone of a good Configuration Management. May be try to find some litterature on these 2 topics.
I'm convinced that xBOMs effectivity management through Change Management is the only relieable way to corectly manage Product informations (and mainly xBOMS) accros company (and IT systems PLM->ERP)
Basically you will need to define in your product which kind of Part you want to "track" in term of composition/interchangeability (for manufacturing or repair and overhaul, etc ... ). They will be for example track by Serial Number.
For basic part that you do not want to track formely, you can use just dated effectivity
Then , you can Use the Change Management process, to set effectivities on the resulting objects in the Change Request/Notices.
That will permit you to manage the "as design" and "manufacturing as planned" views of your product . (let's says for a range of serial numbered parts) And you will be able to forward the effectivity information to your ERP for execution.
After that , you can choose to record also "as built" configuration of a particular instance of your product (for example a particular SN part during his maintenance ... )
Concepts are not necessary easy to explain. But once correctly implemented in Change management accross PLM and ERP, it has real added value .
Regards
Gregory
Oct 4, 2013 3:30 PM UTC
Hi
Can you please exaplain , whats your requirment exactly.
I will try to help you.
-- warm regards
Murali
www.prism-ind.com
http://www.prism-ind.comIndia:+91 888-00-77476
Oct 16, 2013 2:14 PM UTC
Hi Murali,
I would like to know the complete process to assign efectiveness to released parts. A complete guide or example would be very useful.
Carolina
Mar 16, 2015 1:59 PM UTC
Carolina,
It really depends upon what your needs are.
You can apply effectivity to track serial configurations, however if you need to track specific Serialized units that falls under Product Instance capabilities.
We are working on adding to the Help content on Effectivity and you should see some updates in the M030 and more planned for the future.
In terms of the DS/CI pattern discussed above - that is part of the Windchill Aerospace and Defense module and really geared towards aircraft design.
In 2010 I gave a session covering Effectivity - its missing from the PTC/USER library - I am having it added, but am attaching to this reply
Additionally I am attaching another file showing examples of Effectivity basics & propagation
In 2012 at PTC Live I gave a session on Configuration Management that included Product Instances - it can be found on the PTC/USER site in the Library - here is a link to that - http://portal.ptcuser.org/p/do/sd/sid=2010&fid=1458&req=direct
