Sep 11, 2023 2:59 PM UTC
Assigned Plant Configuration Specification and Plant Filter
Hi All,
I am wondering if anyone who is using Plant Data and the view hierarchy which includes Design, Manufacturing, and <Plant> views understands how the new plant based filtering capabilities work?  In the structure filter, users are now able to use the Assigned Plant configuration specification and the Plant Filter.  I have poured over the WHC topic but I'm still not confident in how each one works and the use cases that are solved.  Does anyone have some insight?
Patrick Williams
MarcoTosin
Sep 18, 2023 1:04 PM UTC
Hi Patrick,
can you add some pictures to better explain your question and which version of Windchill are you using?
Marco
