ozclkonur
Aug 20, 2024 4:56 AM UTC
Assistance Required: Uploading and Replacing Modified PDFs in Windchill EPMDocument Attachments via
The PDFs are sent to the attachment section. For example, there are four PDFs created in sequence, but later a user inserts a PDF between them, for instance, between 1 and 2, and assigns it a sheet number of 2. However, because it was originally a PDF with a page order of 5, it naturally appears at the end instead of between 1 and 3. I developed an intermediate application in C# that scans the incoming PDFs using OCR, rearranges them according to the sheet number, and converts them back into a PDF. However, I couldn't find an API that allows me to upload this modified PDF back into Windchill. How can I send or replace this modified PDF in the Attachment section of the relevant drawing in EPMDocument? I couldn't find a way when I looked at the REST APIs in WRS. Could you help with this?
avillanueva
23-Emerald II
Aug 20, 2024 11:26 AM UTC
Just so we can get a sense of your setup, are you uploaded to the attachments section a single, multisheet PDF or one PDF per sheet? Are these PDFs being generated automatically upon check in or using the WVS CAD workers? Is this legacy data importation or newly created data?
