Sep 16, 2024 12:37 PM UTC
Associate WTPart with EPMDocument
Hi, My goal now is to create a EPMDocument in a Workspace with associated WTPart by REST APIs
What I plant to do:
Step1: Create a EPMDocument in Workspace
API: Windchill/servlet/rest/v1/wgm/workspaces/{workspaceId}/store
=> Done
Step2: Create a WTPart
API: Windchill/servlet/odata/ProdMgmt/Parts
=> Error here
My body:
    "Name":"testToday",
    "AssemblyMode": {
      "Value": "separable",
      "Display": "Separable"
    "PhantomManufacturingPart" : false,
    "Organization@odata.bind": "Groups('OR:wt.org.WTOrganization:123')",
    "Context@odata.bind": "Containers('OR:wt.inf.library.WTLibrary:123')"
Error
    "error": {
        "code": null,
        "message": "The wcType: com.ptc.ElectricalPart is invalid"
Step3: Create Association
API: Windchill/servlet/rest/v1/wtparts/{WTPart}/associations/to/documents
Does anyone have faced with similar error in step2? Please help me to fix. Thank so much !
Fadel
23-Emerald II
Sep 16, 2024 3:34 PM UTC
Would you test the steps in https://www.ptc.com/en/support/article/CS398513
Buiꓘa
Sep 17, 2024 1:05 AM UTC
When I visit your link, it show
Note: This article 398513 is not customer visible.
Can you explain the solution in these steps in the comment.
Thank you so much
Fadel
23-Emerald II
Sep 17, 2024 7:12 AM UTC
My bad, indeed the article is PTC INTERNAL,.
The article suggest one of the below  2 options :
  1. import com.ptc.ElectricalPart type from Out-Of-The-Box Windchill into affected environment using LoadFromFile framework
  2. Delete the Windchill REST Services configuration files for Electrical Part
Buiꓘa
Sep 17, 2024 1:43 PM UTC
Your error message applies to step 2 only, so let's look at that and ignore your other steps for a moment.
Look in your 'Type and Attribute Management' under Site Utilities. Have you defined com.ptc.ElectricalPart? Are you able to create a part with this type by using the Windchill 'New Part' UI?
In the Windchill/servlet/odata/ProdMgmt/Parts API, can you do a GET and see the com.ptc.ElectricalPart that you created?
