May 15, 2024 10:30 AM UTC
Association Type - Set as Default
Hi Guys,
In Windchill we can use the "Target State" to set a lifecycle state at a single shot for all the WT Part rights.
I want the same thing for the association type because whenever tried to associate EPM comes as the owner is the default. I want to change into a contributing image.
Can we control through preference management to set my EPM always in the contributing image? If that means WT Part is Owner Right.
Aj
avillanueva
23-Emerald II
May 15, 2024 11:13 AM UTC
This is done via preferences:
https://www.ptc.com/en/support/article/CS340009?source=search
May 15, 2024 11:21 AM UTC
Thanks for the replay @avillanueva
As per the article, we need to change 3 things in Preference Management Right.
AJ
avillanueva
23-Emerald II
May 15, 2024 11:25 AM UTC
I do not think so if you are referring to altering for certain document types. You might want to leave that one alone but read what each one does. Make sure you build a good set of test cases before deploying to production. You want to make sure you hit it from all angles.
Emeritus
May 22, 2024 6:09 AM UTC
Hello @Amirtharaj_K,
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
