6-Contributor
Jan 6, 2017 2:57 PM UTC
Assoicate CAD to WTPart for wires
We have some a scenario where we have some wire that we modeled as a single part; however, the BOM on the drawing we want it to say 500mm.  If I do the Auto-Associate as OWNER, it will come in as QTY.1.  Will the other selections (Content/Image/Contributing Content/Contributing Image) allow for the part associated to be populated in the BOm, but allow me to overwrite the Quantity for the Windchill Part (Gear part)?
Thanks!
Jan 6, 2017 3:27 PM UTC
You can use the bulk item component.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS127515
6-Contributor
Jan 6, 2017 3:31 PM UTC
We aren't using a BULK item since the routing is shown in the CAD.  For example, we may have a drawing with part 12345.prt that defines the drawing; however, we create a 12345-900.prt (900 is out deformed part naming convention) that shows a routed wire or rope or chain, etc.
Then the upper assembly where I would use the BUILD ASSOCIATED PART from WIndchill pulls in the 12345 part, but it always comes in as QTY 1, I would want to update that to say 200mm.
Jan 6, 2017 3:53 PM UTC
Use a repeat region relation for part 12345 that changes the qty to 200 or whatever value you use in that assembly.
IF asm_mbr_number == "12345"
QTY = '200mm"
endif
