Jan 21, 2016 6:55 PM UTC
Attempt to check in files fails, get message: A persistence error occurred. System message follows:
One of the engineers here is attempting to check in models - check in fails and he gets the following message:
He is unable to find the system message to give a clue as to the failure... any thoughts?
2-Explorer
Jan 21, 2016 7:52 PM UTC
Are the other users able to check in files? This sounds like a database issue. Do you see something in the method server logs? Error looks similar to a bug 10.2 M030 with delete workspace
gchapman1-VisitorAuthor
Jan 21, 2016 10:01 PM UTC
I did find the persistence error occurred line
2-Explorer
Jan 21, 2016 10:47 PM UTC
Looks like index is corrupted. After your DB backup try the below
SELECT
OBJECT_NAME,
OBJECT_TYPE
FROM ALL_OBJECTS
WHERE OBJECT_ID = 30101;
If is an index, try rebuilding it
ALTER "INDEX_NAME" INDEX REBUILD ONLINE;
Thank you
Binesh Kumar
Jan 22, 2016 1:30 PM UTC
The last time I received this error I had to check out the WTP's in the same Workspace and check the asm in.  The WTP's got checked in at the same time.
Nov 21, 2017 4:47 AM UTC
Dear gchapman,
Did u resolve this issue?
I'm facing same error while trying to check out the files.
Can you please help out with the solution.
Thanks in advance.
Sumanth
Jun 8, 2021 2:18 PM UTC
Had this issue today.  Same as all no real information as to the cause of the error.  Was checking out a EPMdocument along with 24 WTparts that were associated.  The workaround was to add the objects to a workspace.  Then I checked out only the EPMdocument.  Then I checked out all of the WTparts except the two that was causing the issue.  Then I checked out the last 2 WTparts with no error.
