Jun 24, 2026 4:54 PM UTC
"ATTENTION: Error occurred while saving the resource data" on wcadmin
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2 Currently, I'm having some trouble adding an overview file to the workflows; even with wcadmin, I get the error below. What are the possible issues, and how can I solve them? Here are the errors that I faced ATTENTION: Error occurred while saving the resource data.
Radwan Almsora
Jun 24, 2026 9:38 PM UTC
The "ATTENTION: Error occurred while saving the resource data" error in Windchill workflow administration typically relates to stale server cache, uncommitted database changes, or browser-side cached components.
The error typically points to the UI failing to process, serialize, or save changes to the workflow definition due to corrupted session data or internal server cache mismatches.
Did you find this post helpful? If it gave you one or more solutions,
don't forget to click the Accept Solution button and leave a < like !
Radwan Almsora
18-Opal
Jun 25, 2026 4:32 AM UTC
Hi ​@AN_10574662,
Could you please add some screenshots?
