3-Newcomer
Mar 10, 2023 12:38 PM UTC
Attribute related information from Windchill in XML file
When converting excel file into XML file, under Attribute definition there are few information in converted XML file which is not in excel. Are they static and what are those tags refers to?
Fadel
FadelAnswer
23-Emerald II
Dec 2, 2023 4:01 AM UTC
Generally the the first tag should have the quantity of measure for real numbers with units  like
<csvQoMName>Length</csvQoMName> , in case of loading Options (O&V) this is required only for numeric options
when specifying above , the second tag can hold units for each measurement system like below
 <csvnameValuePairs > CGS ~ cm|MKS ~ m| SI ~ m|USCS ~ in </csvnameValuePairs >
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Buiꓘa
