Apr 3, 2024 11:02 AM UTC
Attributes - Create through loader
Hi Guys,
Can we use the loader to create an attribute name that we can add to the selected WT part?
AJ
HelesicPetr
Apr 3, 2024 3:23 PM UTC
Hi @Amirtharaj_K
Check following article that describes how to export and import the attribute definition in the system.
You can export and check how the XML input files are structured and you can create own to load the attributes
CS30168 - How to export and import soft types and attributes using 'LoadFromFile' in Windchill
PetrH
Apr 29, 2024 4:14 AM UTC
Thanks for the reply @HelesicPetr
Article - CS59960 i refer this to create an attributes.
How can we add attributes to a specific type of WT Part, EPM Document, ECN, and other types?
Aj
HelesicPetr
Apr 29, 2024 5:28 AM UTC
Hi @Amirtharaj_K
Use the export from the article, and you can check the generated xml files that creates the attributes in the soft type as a EPMDocument ECN and so on.
You need to study how the xml is formatted and you will be able to create own definition for the soft type. .
PetrH
