9-Granite
Mar 29, 2024 12:48 PM UTC
Audit Trail Journal
I would like to find the source of the Audit Trail Journal information that shows in the Windchill interface when clicking the Audit Trail Journal icon in the History section of the Timeline tab of the CAPA quality objects.. I would like to find the source either in Query Builder or the database in order to incorporate the information into another report. But I have been unable to to locate the information either in Query Builder or in the database. Does anyone know how to grab this information to include in custom reports? I am using Windchill  version 11.1 M020-CPS17.
Fadel
23-Emerald II
Mar 29, 2024 1:47 PM UTC
I'm not quite familiar with CAPA and QMS , the best reflex in such use case is to enable wt.pom.sql logger , you can then access information from UI , in the logs you will see trace of all DB tables and Queries
Buiꓘa
cmhaka9-GraniteAuthor
9-Granite
Mar 29, 2024 8:16 PM UTC
Hello @Fadel ,
Thank you for your response. How do I enable the wt.pom.sql logger? And once that is enabled are the results viewed in the Method Server log?
Fadel
23-Emerald II
Mar 31, 2024 4:59 PM UTC
Hello ,
check steps  below
BR,
Fadel
Buiꓘa
