Mar 17, 2026 11:55 AM UTC
Auto clear the cache vault/ Uploadvault
Version: Windchill 13.0
Use Case: How to to auto clear the cache vault once the files are moved to the master vault in windchill?
Description:
Fadel
FadelAnswer
23-Emerald II
Mar 18, 2026 11:25 AM UTC
 Set purge / aging properties:
If you want the system to automatically purge aged unreferenced items without you clicking through the UI,  consider setting below properties
wt.fv.purgeUnreferencedFvItemsInterval (days between purges; default 1)
wt.fv.purgeUnreferencedFvItemsOlderThan (age threshold in days; default 30)
wt.fv.purgeUnreferencedMORItemsOlderThan (age for MasteredOnReplicaItems; default 30, min 2)
wt.fv.purgeUnreferencedFilesOlderThan (age threshold for physical files when “Remove Unreferenced Files” is run)
Validate on  a test server first and make sure the sync is working smooth
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Buiꓘa
Mar 19, 2026 12:59 PM UTC
No i want to execute a daily cleanup task and only on the defaultupload vault.
Fadel
23-Emerald II
Mar 19, 2026 1:02 PM UTC
@AP_10483126 implement you own custom code,  Atos is a partner and should have enough knowledge
Buiꓘa
