Sep 16, 2020 11:16 PM UTC
AutoCAD generates error Unable to Save Drawing to Workspace. Drawing saved to Windchill\saveXXXX.tmp
My company uses AutoDesk (Inventor & AutoCAD) products and PTC (Creo) products. For AutoCAD we use the Workgroup Manager and sometimes we get an error during usage that shows belowMicrosoftTeams-image (12).png. I can't trace the source of why it is happening. It basically blocks all the information for saving from AutoCAD once this error is shown to the user. Has anyone else see this? You can delete the local Windchill folder and re-setup the connection for the Workgroup Manager to the CAD tools, however, the user always ends up losing work because of this.
Dec 16, 2020 5:24 PM UTC
Was there a resolution for this? I am also experiencing this problem.
agarr10-MarbleAuthor
Dec 16, 2020 7:13 PM UTC
No we have not found anything. PTC support desk said that I needed log files showing when it happens to diagnosis anything. I don't know the cause so we can't run the logs constant.to capture. The closest information I have found is here: https://forums.autodesk.com/t5/autocad-lt-forum/unable-to-save-files-creating-tmp-files-instead-autocad-lt-2014/m-p/4531107#M117508
I have a test running trying this option: https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-LT/files/GUID-469DFA87-1986-4BDA-918B-1E3F9D6FCDC2-htm.html
Both of those are not for current versions, but I think still apply. We are on AutoDesk 2018, what version are you on?
Dec 16, 2020 7:50 PM UTC
We are also using AutoCAD 2018. For some users, opening the drawing, moving some stuff around and re-saving causes the issue. Clearing the Workgroup Manager cache does help temporarily.
Mar 2, 2021 9:23 PM UTC
There is a new Workgroup Manager (CPS17) that may resolve your issue.
Mar 2, 2021 9:50 PM UTC
Have you tested to see if it resolved your issue?
Mar 3, 2021 3:31 PM UTC
Yes, the update resolved the issue.
2-Explorer
Mar 5, 2021 4:49 PM UTC
We have a similar error using Inventor.  We discovered it was Microsoft OneDrive.  This is how we resolved it.
Cause
  1. OneDrive activated
Resolution
  1. Turn off the "Files on Demand" feature in OneDrive settings
  2. Reboot the client
Once that is done, we didn't see that error any longer.
Mar 5, 2021 4:52 PM UTC
We have tried that with no success in preventing it from happening again.
2-Explorer
Mar 5, 2021 4:55 PM UTC
@agarr  Well, that's very unfortunate.
A second issue we've discovered is that during a Windows 10 update (these happen with no warning) we have the same issue.  However once the update is complete, and you've rebooted all is well.
Could your problem be occurring during a Windows update?
