Jan 16, 2015 2:45 PM UTC
AutoCAD P&ID with PDMLink
HI,
I know that we have a workgroup manager for AutoCAD integration with PDMLink.
But, how can i use AutoCAD P&ID with PDMLink?
Assuming that Windchill PDMLink 10.2 and AutoCAD P&ID latest version.
Hari Varadharajan
Jan 16, 2015 2:53 PM UTC
I need this too, but haven't figured out why the standard WGM will not work.
The WGM should modify the toolbar through the CUI of AutoCad, so that should be common.
The file format of a P&ID file is standard AutoCad DWG format.
The only difference between AutoCad and AutoCad P&ID (and Mechanical, Electrical, etc) is the libraries that are included with the package, from wjaty I can tell.
Why is PTC saying that the only support the base AutoCad and not the packages in the WGM?
CraigPater
Feb 3, 2015 8:27 PM UTC
Only AutoCAD, AutoCAD Mechanical and AutoCAD Electrical are officially supported per the support matrices: http://support.ptc.com/WCMS/files/157177/en/Windchill102M020CPS03CADIntegrationMatrix12914.pdf.
I'd suggest creating a Product Idea to make Product Management aware that it is something you're looking for.
Feb 4, 2015 3:41 PM UTC
I have created a Product Idea named "Have the AutoCad WGM support all extensions" for this.
Please vote if you need all AutoCad packages supported by the WGM.
