Apr 1, 2016 1:58 PM UTC
Automatically Create the Change Notice
When I go to create a new Change Notice, I open the form and select the box for Automatically create the Change Notice and then Complete Task. I get a pop-up saying I don't have permission to view the subject. What do I need to change to get access to complete the task? I am the system admin!
If I do not check the box for Automatic, the system says I need to create the change notice manually.
Windchill 10.0 m040
2-Explorer
Apr 1, 2016 3:35 PM UTC
I assume it is not an ACL issue, as you are the system administrator.  I remember facing the issue (with Oracle DB) when some of the indexes went to disabled state. You can check it using the below query
select index_name, table_owner, table_name, status,funcidx_status from user_indexes
where funcidx_status = 'DISABLED'
If you find it disabled, you can enable it by running  "alter index index_name enable"
Not sure whether you are facing the same issue, but it is worth checking
Binesh Kumar
BenLoosli23-Emerald IIIAuthor
Apr 1, 2016 6:05 PM UTC
No rows returned
I did not set up the system, so it may be an ACL issue that I haven't found yet. I have put myself in all roles for change request and those assign me tasks and I can complete them. I did complete the review task before the Change Notice creation was triggered.
