Sep 27, 2023 7:30 AM UTC
autonaming not visible fully i want to apply it on different field instead of name field
I am using Windchill PartsLink Release 11.2 and Datecode with CPS 11.2.1.10
classification my naming is not visible fully and my name field contains the length only 60 character and my autonaming length is around 94 character so that's why it is not showing full naming and we can't change length of the name field. so my question is we can apply the autonaming rule to the different field like description or any other attribute instead of name field?
Here are the errors that I faced
HelesicPetr
Sep 27, 2023 7:34 AM UTC
Hi @SD_10636834
Have you tried to increase the name length ?
How to extend the length of the WTPart's "Name" attribute
PetrH
Sep 27, 2023 7:56 AM UTC
yes i have tried this one but still it is not working i just want to know that the autonaming rule is possible to apply different field instead of name i want to apply this on description field so it is possible?
HelesicPetr
Sep 27, 2023 8:04 AM UTC
Hi @SD_10636834
OOTB I don't think so.
but you can try to define OIR rule for the system attribute description or what attribute you're using
<AttrValue id="description">
<Attr id="name"/>
</AttrValue>
<AttrConstraint id="description" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
</AttrConstraint>
If OIR does not work I can imagine some customization.
PetrH
