Feb 28, 2024 11:24 AM UTC
Autonaming rule
I am using Windchill PartsLink Release 11.2 and Datecode with CPS 11.2.1.10
I have created attributes in Partslink as O-ringID, while entering the attributes value if user enter single digit then I want two decimal digit after that user input in autonaming rule. for ex- user enter 5 then it should be 5.00 in Autonaming rule like (O-ringID_5.00) and if user enter 5.15 something like that, then it should be as it is.
Here are the errors that I faced
    Community Moderator
    Mar 6, 2024 5:01 AM UTC
    Hi SD_10636834,
    Thank you for your question.
    I’d like to recommend to bring more details and context to your initial inquiry.
    It also helps to have screenshot(s) to better understand what you are trying to do in your process.
    Community Moderation Team.
