3-Newcomer
Feb 15, 2020 3:26 PM UTC
available options in Publish Rules XML file
What options are available for publishing to PDF in the Publish Rules XML file?
I want the JPG images to be displayed in the PDF generated by the worker.
Thank you.
vdegaonkar
Mar 4, 2020 4:55 PM UTC
Publishing Rules for generation of additional file formats like PDF varies with adapters. All available options are documented in "Creo View MCAD Adapters Installation and Configuration Guide" with respective adapter.
Can you provide more details on use case or problem that you are trying to address here.
Docserta3-NewcomerAuthor
3-Newcomer
Mar 4, 2020 6:06 PM UTC
when I publish a Drawing (catia) with an image view (BMP) it does not appear in the PDF.
