18-Opal
Aug 26, 2024 11:27 AM UTC
Best practice to handle revision of Standard Part
In Supplier Management,
When Standard Part is released through New Part Request and If Part has to be revised for changes?
How do we proceed?
1. Do we use change management or New Part request to release the new revision?
2. How supplier will be notified that Standard part i.e Manufacturer part has to be modified and what modifications are needed?
HelesicPetr
Aug 26, 2024 12:11 PM UTC
Hi @TDT
If you say Standard Part from my point of view this standards should never change so you should create a new standard part and replace it in a assembly.
PetrH
TDT18-OpalAuthor
18-Opal
Aug 27, 2024 11:50 AM UTC
Hi @HelesicPetr,
Thanks for the information.
In that case, Instead of loading new supplier parts and creating a new standard part,
Do you see revising the supplier part and creating a new standard part for the revised supplier part as best practice?
HelesicPetr
Aug 27, 2024 12:24 PM UTC
Hi @TDT
I don't understand the question
You mixed two things. Supplier part that is created by some outsource company and standard part where standard means there can not be any change because it is standard.
Example: You want to manufacture screw and if you change a shape of a screw head, then it is definitely different screw with different number.
PetrH
