Aug 29, 2025 6:00 PM UTC
Best practice to migrate an assembly from one windchill server to another?
Version: Windchill 12.1
Use Case: Transfer CAD/Part structure from one windchill installation to another
Description:
Is there any method or a best practice to transfer a CAD assembly and its associated parts to a different windchill server? Historical information isnt required. Essentially need to delivery a duplicate CAD model and part structure to another windchill installation.
d_grahamAnswer
18-Opal
Aug 30, 2025 4:32 PM UTC
That’s precisely what “Packages” are intended for.
Easy to use too.
Hint: make sure your Cad worker is running when you zip the package delivery.
d_graham18-OpalAnswer
18-Opal
Easy to use too.
Aaronm8714-AlexandriteAuthor
Aug 31, 2025 3:48 PM UTC
Thanks! Looks like we dont have the appropriate license though. I can only select the Export option.
18-Opal
Aug 31, 2025 7:28 PM UTC
If you can’t use Packages I’d suggest opening the assembly in the native cad system, Creo Parametric for example.
Backup the assembly to disk.
Open assembly in a session linked to your other Windchill instance, Save, set folder(s), Check in.
That would get it there too.
