Aug 28, 2018 1:07 PM UTC
Best Practices and Guidelines - Windchill Change and Configuration Management
In the context of considering a very large Enterprise Change and Configuration Management process, we are currently looking at the best practices and guidelines associated to managing change and configurations within Windchill;
We would need to be able to clearly check all capabilities and features for envisioning what can be considered as part of the Windchill landscape, associated to several heterogenous systems which can be federated, aggregated and orchestrated using specific middleware layers based on ThingWorx
In case anyone has anything to share in this area - restricted to Windchill and/or extended to any interfaced system(s) - please provide your own field experience, expertise and associated communication materials; this will help our very large program as well as anyone involved into Windchill Change and Configuration Management Processes for considering several implementation layers most essentially using OOTB layers provided by PTC Windchill (and Thingworx)
Jan 14, 2019 7:13 AM UTC
Hi,  do you have any update for this , I need the solution .
May 10, 2019 1:08 PM UTC
Just stumbled on the attached docs: hope it helps? PDF: "Best Practices for Options and Variants White Paper"
May 10, 2019 1:30 PM UTC
Use that document with caution. It is 12 years old which means Windchill 8 or maybe 9. Things have changed in Windchill since then.
May 10, 2019 1:41 PM UTC
Yes, system-wise the implementation might be different, while the higher-level concepts for ETO, CTO, ATO, etc... are pretty much the same --- is there any updated version of this white paper or any similar document related to Windchill 11 ?
May 16, 2019 3:55 PM UTC
@JeffZemsky
maybe you would like to chime in?
I know that PTC has plan to release new Windchill functionalities around Enterprise Change Management.
