beyond Intralink 3.4
We are in the process of finding a data management solution. The bulk of our work is engineering consulting so we usually don't carry a product through the entire lifecycle. At minimum we need rev control, renaming, parameter mapping and bom creation. To throw a wrench into all of this, it would be really nice if this system could also manage the "dark side" files (SWX). We are currently demoing some systems but I'm curious to know anyone's experience using Concurrent DDM and/or Autodesk Vault Professional. I understand that PDMLink with Workgroup Manager will handle solidworks files but I would like to know what else is out there. I also understand that 3rd party systems are usually behind the compatibility curve with the latest Pro-E release.
Any nuggets of wisdom are appreciated.
-hs
Only advice I would add here would be to stay away from Windchill
pdmlink or Intralink. Unless you have hundreds of thousands to throw
away, and like everything taking 20x longer than 3.4. Youd be better
off printing a hardcopy of every document and using a filing system from
1912. Had it 6 months now. It gets no better.
